86-89 Buffer Box Installation
Old Jan 22, 2016 | 02:29 PM
gearhead141's Avatar
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
I have been gathering parts to change my 1985 cable speedo cluster to the later electric speedo cluster. I have the cluster, a buffer box with bracket, and the speed sensor. I looked at the angelfire site for installation notes and I have pored over and printed the install done by Lilski.
I neglected to take photos when I got the buffer box at the salvage yard. What would really help me is a photo of the buffer box mounted to the ECM and its associated wiring. I have cruise control so I want to be sure I connect that wire properly. The install done by Lilski and the website notes did not seem to care about the cruise hookup. I'm just wondering if there are any wires that go from the buffer to the ECM? Perhaps a picture will be worth a thousand words!
Old Jan 25, 2016 | 11:55 AM
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Re: 86-89 Buffer Box Installation
I'm sure I'll get this figured out. For any of you that have changed from the 85mph cable speedo cluster to the newer electric 120 or 140mph cluster, how do you like it? Have you had any problems? Is the newer cluster better or worse as far as reliability? I understand that the fuel gauge is buffered so it should be much more steady than the unbuffered unit. The other thing I think I would like better is that the odometer has six places instead of five and the trip meter reset is puch button instead of the clock type reset.
Old Jan 25, 2016 | 09:31 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Here's the shop manual schematic for the 86 Firebird. It shows all the connections that your looking for. Since your car is an 85,... you might want to double check that the wiring matches your car.
Example: Be sure that your 85 ECM accepts VSS input at PIN 'A10' on plug C1.
Full Sized:
http://berlinetta.info/media/shopman...86Firebird.jpg
BE SURE to get a pin-out for each of the 2 clusters that your working with. Print each of them out and compare each pin on the connectors wire-by-wire to be sure everything will match up OK. At the minimum,..... you will need to add 1 wire to the C1 cluster plug for the VSS signal @ PIN 14.
Old Jan 26, 2016 | 10:43 AM
Car: 1985 Trans Am
Engine: LG4
Axle/Gears: 3.08
Thanks John. That helps out quite a bit. It confirms some things I was wondering about. My '85 Firebird shop manual has a wiring diagram for the digital cluster, and it is much the same way. I agree with you that the pinout is the most important aspect of the project and I am looking at that very closely.
Old Jan 26, 2016 | 11:44 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
89irocz355
101
Sep 19, 2016 04:05 AM
instaldave
Apr 18, 2016 07:38 AM
Eric-86sc
Jan 3, 2016 10:39 PM
camaroz1979
Dec 4, 2015 06:08 PM
bigarmzz
Nov 25, 2015 08:13 PM
