Re-installing V6 Wiring Harness
Old Feb 26, 2016 | 02:06 PM
gladback007's Avatar
I am trying to install a 3.1 L V6 body and engine harness back into a 1991 firebird. The piece that I can't figure out is how the positive and negative battery cables are routed. The battery in the car was originally routed on the driver side and the harness did come out of this car originally. The positive battery cable has about 4'-5' of wire and then connects into a distribution block that appears to mount above the canister on the passenger side. The negative battery cable has a bracket about 2-3' from the end that appears to need to mount to something. Photos of any and every connection point on this wiring harness would be very helpful as I wasn't the one to pull this out of the car.
Thanks,
David
Old Feb 28, 2016 | 04:05 PM
Re: Re-installing V6 Wiring Harness
Any photos showing the wiring harness on a car with he battery on the drivers side will be helpful.
Thanks,
David
