Car Not Holding Charge?
Old Mar 13, 2016 | 08:44 PM
That Sky Guy's Avatar
Hi all,
I've had this problem for a while now, and I intend to fix it.
I own a 1989 RS, 2.8L 173 CID V6. Before I got deployed about three months ago, I put a new battery in my Camaro to try and combat the problem. However, the vehicle just cannot hold a charge.
When I was driving it daily, I never had this issue. But now that it's only being driven weekly while in the care of my family, it has died. Refuses to hold a charge. What's the issue here?
**EDIT: On a side note, I am still working to undo the damage the previous owner did to her. He installed three aftermarket pieces of electronics, one of which (or maybe all of them) I suspect to be the culprit(s).
-aftermarket radio/tweeters
-aftermarket, non-factory security system (my suspicions lie here)
-aftermarket HID headlights
Thoughts?
Last edited by That Sky Guy; Mar 15, 2016 at 07:45 AM. Reason: Revision based on possible suspects of issue
Old Mar 14, 2016 | 03:32 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Car Not Holding Charge?
Take it to a auto parts chain store like Oreilles or even AutoZone and have them test the car.
They can tell you if the battery has a bad cell or if the alternator is going out and even information on the condition of the starter. For free and a few minuets of your time.
Or just watch a video or two on testing your alternator with a multi-meter and check it yourself.
The battery has to be under load to be tested properly. = auto parts store.
Old Mar 14, 2016 | 07:39 AM
Thanks, Ron! I'll keep those options in mind!
Old Mar 14, 2016 | 08:18 AM
OrangeBird's Avatar
Car: 1989 Firebird
Yes Sir , your two possibilities are either that the alternator isn't keeping up with charging the battery , or , it sounds more likely here that somethings draining the battery when the car is off . If a fully charged new battery can't sit in a car one week untouched and start the car on day 8 , there IS something excessively drawing on it cause any decent battery even in a modern car should be able to sit a lot longer than a week without needing a jump .
Old Mar 15, 2016 | 07:40 AM
I appreciate it good sir! Thank you!
live4formula
May 25, 2021 08:25 PM
gmglenn99
May 13, 2016 12:59 AM
luvmea3rdgen
Mar 10, 2016 08:36 PM
bryanwood74
Mar 9, 2016 09:34 AM
86camaroman201
Mar 7, 2016 08:21 PM
