1992 instrument cluster. Help needed.
Old Mar 31, 2016 | 08:22 PM
adamcgodby's Avatar
Car: 1992 z28 Heritage Edition
Engine: 357ci SBC
Transmission: TH-350
Axle/Gears: Stock axles with 3.73 gears
I have a 1992 z28 25th anniversary edition. I bought it off a co worker who has taken out the tpi 305 and built a 350 and put in it. The TPI wasn't enough to power the 350 so he changed it over to carburetor. It now has a Holley 650 2 barrel on it. Everything on the gauge cluster works. Temp, fuel, oil press, tach and speedo. They all work but the tach does not read correctly neither does the speedo. Is this a simple fix or do I need to buy a whole new cluster (Dakota digital is all I can find for $755). It does have the 700r4 in it. Thank you any help is appreciated.
Old Mar 31, 2016 | 08:30 PM
adamcgodby's Avatar
Engine: 357ci SBC
Re: 1992 instrument cluster. Help needed.
350 bored 40 over, flat top Pistons, hydraulic roller cams, ported and polished heads, valve work with bigger springs.
700r4 with corvette servo, stage 2 shift kit, 2400 stall and 3.73 gears
Old Apr 1, 2016 | 09:41 AM
OrangeBird's Avatar
Car: 1989 Firebird
There is a common failure of our tach that involves a resistor going bad and it is easily repairable by someone with electronic know how , if it is in fact that failure . A search of this site will turn up threads about it .
and 3.73 gears
And if it came with other than 3.73 , that's likely why your speedometer doesn't read right . If this is the case , the gears for the VSS will likely need to be changed . Again , there are threads to be found here dealing with ratio changes and how to get the right gears for the right ratio .
scoutcamper
Jun 15, 2017 01:55 AM
unseenT/A
Mar 1, 2016 05:55 PM
jshaf00
Carburetors
Feb 16, 2016 07:09 PM
Peter1970
Feb 15, 2016 09:14 PM
82Brlinetta
Feb 14, 2016 08:53 PM
