90 Camaro RS - Speedometer and Odometer stop intermittently
Old Jun 4, 2016 | 11:30 AM
puma1552's Avatar
I had the car out this morning for a cruise, and about 2 miles from home the speedometer dropped to 0 and the odometer quit rolling. For the remaining 2 miles home, they seemed to both start and stop working together, several times. The rest of the gauges work fine.
Is this a VSS in need of replacement, or something worse in the dash/gauge cluster? I don't want to drive the car with the odometer not working correctly. Currently has 154k miles on it.
Old Jun 11, 2016 | 10:35 AM
puma1552's Avatar
Re: 90 Camaro RS - Speedometer and Odometer stop intermittently
nobody has had this happen?
Old Jun 11, 2016 | 12:41 PM
Camaro86IrocZ's Avatar
Car: '86 Iroc Z & '91 RS
Engine: 305 TPI & 305 Qjet - Future LC9
Think of it as a way to keep it from racking up even more miles..
No clue as for reason, except for maybe checking all the connections first.
Old Aug 15, 2016 | 10:34 PM
puma1552's Avatar
Doing more research, seems a code 24 is the code for a bad VSS, but a lot of conditions need to be met to throw a code 24.
I just jumped the ALDL with a paperclip to read codes and there are no codes.
Haven't driven the car in two months.
notrabies
Jul 29, 2016 09:39 PM
EDGE
May 19, 2016 10:26 PM
ryan thomas
Apr 16, 2016 04:45 AM
dennisbernal91z
Apr 14, 2016 05:42 AM
stegal
Apr 6, 2016 03:33 PM
