What are gauges run off of in 91 camaro?
Old Jun 18, 2016 | 05:42 PM
"John"'s Avatar
Car: 91 Camaro RS
Engine: 350 crate engine 360ish HP
Transmission: T5 5 speed manual
Axle/Gears: 3.42 10 bolt POSI
I plan on going from 305 tbi t5 to carb 350 t56. It is my understanding that all the gauges run off of the ECM. What will need to be done to make them work? Or at the very least, the speedometer.
Old Jun 27, 2016 | 04:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Misunderstanding Commanding
NONE of the gages are controlled by the ECM.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Old Jun 27, 2016 | 07:37 PM
"John"'s Avatar
Car: 91 Camaro RS
Re: What are gauges run off of in 91 camaro?
What does the Speedometer run off of? It was my understanding that that did, but the tach ran off the distributor.
Old Jul 4, 2016 | 03:46 AM
stickychinsac's Avatar
Car: 91 Bird
Engine: 350 carb
Axle/Gears: Strange 12 bolt, 4.11
Possible, some years the vss was part of the ecm I believe. I have a 91 firebird (was 305 tbi) it had a seperate vss. Only wire that went to the ecm was the high speed cut off. Dakota digital box will take care of it if needed. The other gauges will work, they are on the drivers side harness. You will lose the fan control. The computer uses the temp sensor on the passenger side head for that. There are stand alone sensors to take over that responsibility.
wkropp16
Jun 20, 2016 06:22 AM
snakeshooter
Jun 14, 2016 07:29 PM
1990rs305
Jun 9, 2016 08:04 PM
kurtis72
May 30, 2016 06:15 PM
87zz28
May 25, 2016 10:25 PM
