No heat
Car: 85 Camaro RS
Engine: GEN I sbc 5.7, .040 over
Transmission: 700R4 Slushbox dreamkiller
Axle/Gears: 3.42 posi
No heat
After replacing my ignition and headlight dimmer switches in my 85 camaro, I noticed that my blower motor as well as the whole hvac control head doesn't work at all. I know I unplugged a few thing around the column wjen I was replacing the switches but im pretty sure I buttoned everything back up. Is there any wiring for the hvac that runs anywhere near there? The blower motor operates when I put 12v to it and the fuses are good.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You’re Getting Warmer
With the key in the RUN position, and the Mode Control in the VENT position, probe both brown wires.
Do they both have power?
If no, does one?
If no, check the HTR A/C fuse even tho you said they look good.
Is there power both sides of the fuse?
COOL▬▬▬▬▬▬▬▬▬▬▬▬WARM
Happy Racing !
We Keep The Air Wrench Shiny So It Looks Good When We Throw It Across The Pit Box
If no, does one?
Happy Racing !
Car: '89 Firebird
Engine: 7.0L
90 L98 TransAm
Exterior Parts for Sale
Mar 30, 2016 05:33 PM
