Gauge fuse keeps blowing
Old Aug 2, 2016 | 10:09 AM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
What's up guys I got a 91 trans am with a 350 tpi. Today I was driving to work and all of a sudden the gauges went out. I replaced the fuse and instantly the fuse blew again. I've never had problems with it before all nova sudden it popped. Any idea where I should be looking for a short
Old Aug 15, 2016 | 04:38 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Outrages Gages
Disconnect the connector behind the dash.
If the fuse still blows you will know the short is in the wiring from the fuse block going to the dash.
If the fuse no longer blows you will know the short is in the dash.
Happy Racing !
Whether The Street Car At A Traffic Light Or The Nitro Funny At The Strip, Yellow Means Floor It !
Old Aug 15, 2016 | 06:55 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Gauge fuse keeps blowing
I think the TTC is also run through the gauge fuse.
Old Aug 15, 2016 | 07:41 PM
As well as, a bunch of the "driven" type things under the hood that the ECM works: EGR, AIR, stuff like that. The pink/blk wires.
Old Aug 17, 2016 | 10:28 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If your drivin' the 1991 Trans Am GTA, check to see if a dime fell in the cigarette lighter socket.
If the lighter socket is clear - or if you're workin' on a I_R_O_C_Z_2_8 - then you'll need to check every accessory that's connected to the Gauges fuse.
Old Aug 18, 2016 | 10:18 PM
Engine: 350 tpi
I accidently clicked theare a report button and replies sorry about that. But I figured it out the wires from the smog pump where touching the edelbrock runners. I forgot I had taped them off when I cancelled the pump. But I got it no more fuses blowing. Thank you for all the help.
Old Aug 24, 2016 | 10:18 AM
ViperSpec's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Axle/Gears: 3.27 (Stock)
My issue wound up being chaffing on the harness above the fuse block. On the upper portion of the drivers kick panel area the harness was contacting and rubbing against a metal support and shorting out the power wires from that fuse. Repaired the damaged area and re-secured away from the contact point. Has been good ever since.
notrabies
Jul 29, 2016 09:39 PM
90Camaro5speed
Apr 2, 2016 02:41 PM
mclenty0
Mar 19, 2016 11:36 AM
liva687
Mar 16, 2016 09:00 AM
HotZ
Aftermarket Product Review
Oct 17, 2001 03:52 AM
