Check engine light stay on all the time but dim. No Codes
Car: 1989 IROC Z L98 G92
Engine: 5.7
Axle/Gears: 3.27 G92
I was wondering if anyone else has had this problem. After changing all of my IP light bulbs to LED, my CEL light stays on all the time but real dim. I check for codes and none come up and light will flash like normal for the code 12 but instead of flashing on off it will flash bright to dim. Any help would be appreciated.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
LED Sled
Thats because it takes so little current to activate the LED.
You can cure the problem with a 56 ohm resistor across the lamp socket.
Happy Racing !
! Drive It Like Youre Renting It !
Happy Racing !
Car: 1991 Camaro RS
Engine: 305 TBI
Re: Check engine light stay on all the time but dim. No Codes
Had the same problem and with the air bag light also. I also put the regular bulbs back in.
Axle/Gears: 10 Bolt 2.73 Open
Wow...the things I learn hanging around this place....
