Im looking to get another thirdgen-key question
Old Nov 17, 2016 | 06:46 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Hello, well cutting to the chase, i'm going here in a couple days to look at at a 89 iroc. The guy said it'll run and drive but the heads are clogged (which ive never heard or seen) and he lost the key. So, i believe the 89 doesn't have the resistor in the key, or am i wrong? If not can i simply just senf 12v to the coil and jump the starter to start it? I understand the wheel will be locked but i just wana hear it run.
Old Nov 17, 2016 | 07:48 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Im looking to get another thirdgen-key question
89's have VATS. You will have to bypass the VATS module, And if you do that, you will need to know the resistance.
Here is the chart.
VATSResistanceTable (1)
Old Nov 17, 2016 | 09:30 AM
bigreed91's Avatar
Car: 1990 camaro rs
Damn, idk whats been done to this car either. Mine was a 91 tbi. This car looks to be carb but from what ive looked up an 89 iroc should be tpi
