Closed loop Question
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
If there's no CAT and no O2 sensor behind, will car run in closed loop all the time?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Closed loop Question
I thought there were two 02 sensors, the second behind the engine on the CAT. Is that right?
Engine: 4++,350 & 305 CIs
Only on 96 and up cars
Thank you.
Turns out I have a Code 56, bad ECM. Could be a bad solder or EPROM.
