Fuel Gauge
Old Dec 19, 2016 | 04:58 PM
Vanilla Ice's Avatar
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Fuel Gauge
I am working on my dash and gauge problems. I took apart the gauge bezel and tapped all of the gauge needles and noticed the gas needle is the only one that won't move without force. Is that normal? It's been stuck on full since I bought the car, but I haven't checked the under side. Just thought that was strange.
Old Dec 19, 2016 | 06:22 PM
Matt trans am's Avatar
Car: 1985 trans am
Re: Fuel Gauge
Fuel sending unit
Old Dec 19, 2016 | 07:40 PM
Engine: LB9
Axle/Gears: 3.08
Re: Fuel Gauge
That is not the answer.
Old Dec 20, 2016 | 07:23 PM
MSgt Luttrell's Avatar
Car: 1986 IROC Z28
Engine: Carburated small block 454
Transmission: Level 3 Raptor 700R4 2600 stall
Axle/Gears: Strange S60 3:73 S Trac Posi
Re: Fuel Gauge
If the needle is stuck above full, the needle could be sticking on the metal bezel. If that is not the case you have an open circuit that is usually a bad sending unit in the tank; I got lucky and found that my wire connector from the tank to the body harness was dirty and just needed cleaned and reconnected.
Old Dec 21, 2016 | 10:17 AM
Engine: LB9
Axle/Gears: 3.08
Re: Fuel Gauge
The needle isn't sticking and I know I need to fix something on the sender.
The needle itself is stiff. Hard to move physically.
Old Dec 21, 2016 | 10:46 AM
Car: 1986 IROC Z28
Re: Fuel Gauge
The needle should not be difficult to move, I would suspect a bad gauge.
Vanilla Ice
Car Audio
May 12, 2017 10:54 AM
