Help! Wont Start?
Old Jan 30, 2017 | 07:29 PM
Chase Mayabb's Avatar
Car: 1984 Camaro z28 H.O.
Axle/Gears: 373 Posi
Help! Wont Start?
I have an 84 z28 5 speed. This morning I was heading to work and out of no where everything shutoff. after several attempts of trying to crank the motor over i realized i was getting no where. The battery is not dead. but when i go to turn the ignition to acc i have no radio, power windows, no gauges. when i try and turn it over there is no sound as if a starter isnt engaging or the battery is dead its just dead silent. this is my daily driver and need to get it back up and running ASAP if anyone has experienced anything like this please leave some details on how you fixed it.
Old Jan 30, 2017 | 08:18 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help! Wont Start?
Sounds like you hove no power to the fuse box. The power from the battery cables goes to the starter lug. A fusable link wire goes from there to your fuse box. I would be looking at the fusable links at the starter first. And power and ground connections.
Old Jan 31, 2017 | 12:02 PM
JoeMonte's Avatar
Car: 1985 Pontiac Trans Am WS6
Engine: 360ci sbc
Transmission: T-5 non-WC
Are the terminals tight on the battery? Sounds simple but it can be something as easy as that.
Old Jan 31, 2017 | 09:01 PM
Could be a batt terminal, or something similar. Although usually, if a connection between the car and the batt goes bad, the car will keep running, but then after you shut it off, won't do diddly when you try to start it back up. Won't generally kill it driving down the road. Not generally although there are the occasional exceptions.
Most likely though, it's one of the fusible links, as said. (which I guess really is something pretty similar to a batt issue)
Old Feb 13, 2017 | 10:50 AM
Sorry for the late reply but it ended up being the fusible link at the starter that had been melted in half by the exhaust heat. Cheap and easy fix total coming to around 5$ thank you for the help
