86 trans am firebird head light problem. Please help.
Old Mar 2, 2017 | 06:31 PM
happyhapka's Avatar
Car: 1986 Trans AM WS6
Engine: 383 Vortec TPI, PUTS SMILES ON FACE
Transmission: PATC LVL 3 Raptor Transmission
Axle/Gears: 3.27 POSI 9 BOLT
Ok so my driver side headlight motor quite working. So i sent it off to get it rebuilt... i got it back but it willonly go down and not up... even when its out of the car it only spins one way one way (spins down) and when i turn them on it doesnt goe up...any idea what is going on?
the passenger side motor works fine.. just issues with the driver side
Old Mar 2, 2017 | 06:56 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: 86 trans am firebird head light problem. Please help.
Looking at the wiring diagram for 1986 I see your car has the older , relay equipped system rather than the later system that uses an electronic control module in place of the relays . You system has an "Isolation relay" , two "actuator relays" , and two "actuator switches" . The relays function in a standard "reversing switch" configuration to lift and close the doors , with their end travel controlled by the actuator switches .
How to troubleshoot ? Well , if you have limited electrical/electronic experience the best things to do are to check the easy stuff first . Since one side does travel both directions correctly you could try swapping the two actuator relays to see if the problem changes sides . If it does , then that actuator relay is bad . If the problem stays on the same side with the actuator relays swapped then more troubleshooting will be required but hopefully we get lucky and the problem does change sides meaning a new relay will solve the issue .
So swap those two relays and then post up your results .
Old Mar 2, 2017 | 07:06 PM
happyhapka's Avatar
awsome thanks... were are the relays located?
Old Mar 2, 2017 | 07:19 PM
OrangeBird's Avatar
Car: 1989 Firebird
That's a darned good question that I do not have a solid answer to , because my 1989 bird has the electronic module instead of the relays so I can't lift my hood to check . If I were forced to offer a guess I'd look in the general area of the headlights themselves and maybe follow the harnesses where they come from the headlight motors to see if they are nearby .
Old Mar 2, 2017 | 10:45 PM
happyhapka's Avatar
Ok so there are 2 relay.. one in front of the battery and on the passenger side next to the coolant resivour i replaced the driver side on and my problem was solved.... thank you very much for your help.... i love this forum.
Old Mar 3, 2017 | 09:09 AM
OrangeBird's Avatar
Car: 1989 Firebird
Gotta love a happy ending , I'm glad I could help .
