91 Camaro No Crank, No Start
Old Apr 16, 2017 | 09:15 PM
91Camaro350SBC's Avatar
Car: 91' Camaro Z/28
Engine: 5.7 TPI
Axle/Gears: G92 3.42
Went to visit the family for Easter and after a nice time of a get together, I went into the car and put the key into the ignition turned it to the on position and tried to give the car a crank only to ultimately realize the car was flashing its lights and wont crank at all. I then frantically tried to start the car but to no avail. This car's headlights wont even turn on, neither the dome light. No power anywhere. I set up a jump, still absolutely nothing! The wiring for the vats is all in place and the white and black wire are in contact. So i just cant see how that's the problem Maybe it is a fuse? Please help. Thanks for your time.
Old Apr 17, 2017 | 10:55 PM
Engine: 5.7 TPI
Re: 91 Camaro No Crank, No Start
Figured i mine as well say how i solved it, what was wrong was a bad negative connection. That is all. I hope this helps anyone that may have the issue.
Old Apr 18, 2017 | 09:27 AM
brianlibby791's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7L 350 TPI (Deleted Cats)
Axle/Gears: Original 3.27
Is there an aftermarket security system in the car? If so that could be an issue. But the negative ground sounds a little more reasonable. Check your fuses too. Could have blown more then one
