1991-1992 - 145mph cluster issue above 80mph
Old Apr 17, 2017 | 04:03 PM
LS2Swapped92's Avatar
LS Swapped, stock gauge worked fine 0-100+ with dakota SGI-5.
I bought a 145mph from someone and when it gets to 80mph, it wont go any higher
Is the gauge shot, or is there something I'm missing here?
Old Apr 24, 2017 | 08:40 PM
diamjim's Avatar
Car: 1992 RS Camaro
Engine: 383
Re: 1991-1992 - 145mph cluster issue above 80mph
Did you re-calibrate your Dakota SGI 5 with your LS swap? Which also includes the 145 MPH cluster as well.
Old Apr 24, 2017 | 08:42 PM
Ls Swapped it in 2013. Old cluster was calibrated, new cluster works accurately up until 80mph before it stops
