Help with in-line fuse location to Rear Hatch
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Hey guys (87 IROC Camaro) little more help with this location, heard the inline fuse for the rear hatch switch on ANOTHER OLD thread was located in this area? There is a inline fuse under the ds dash close to the fuse box. I have been underneath there once...is it to the right of that fuse box and I assume you can just open up the box and I assume its there...anyone know what is called or amp it is...guess I could just take a multi-meter to all the fuses. Sorry for the dumb questions...at training with the military and will be gone for a while...taking some down time to ask questions so when I get home I can tackle it! Thanks!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Help with in-line fuse location to Rear Hatch
The relay should be on a 20amp circuit acc fuse.
Engine: Lb9
Transmission: M20
On Probation
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
FWIW, the hatch release circuit runs through the 20-amp ACC fuse in the fuse box, located to the left of the steering column.
There shouldn't be any in-line fuse for the hatch release.
