84 Berlinetta
Old May 2, 2017 | 10:50 PM
That1Skater's Avatar
Car: 1984 Chevy Camaro Berlinetta
Engine: V8 4 barrel
Axle/Gears: Stock
84 Berlinetta
Sobive recently picked up a 84 Camaro Berlinetta. I went to go mess with the fuse box with a diagram i had. Now it doesnt want to turn over it just clicks when it was running just before my voltage gage say im at 13 but when i turn it over it clicks and everything seems to turn off but the temp gauge which reads accurate. Im not sure what it could be. HELP!!
Old May 3, 2017 | 02:46 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: 84 Berlinetta
Check the battery voltage and charge if needed
Old May 3, 2017 | 05:32 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: 84 Berlinetta
Most likely, especially if you messed around in the fuse box with the battery still connected. I love Berlinettas....Let's see some pics! :P
Old May 19, 2017 | 06:53 PM
Engine: V8 4 barrel
Axle/Gears: Stock
Re: 84 Berlinetta
Thanks guys i fixed it lol mt next problem is my tranny (700r4) is stuck in second, tried to up shift to get up a hill now its stuck in second. I NEED TO FIX ASAP! Im visiting cali and i have ro be home before the 25! HEEELLLPPPPPPP
Old May 19, 2017 | 07:00 PM
LiveIt!'s Avatar
Re: 84 Berlinetta
That's weird, but you'd probs get more responses if you post a new thread in the Transmissions and Drivetrain forum
https://www.thirdgen.org/forums/tran...ns-drivetrain/
Old May 19, 2017 | 07:32 PM
Engine: V8 4 barrel
Axle/Gears: Stock
Re: 84 Berlinetta
Fixed it temporarily , a piece of my shift linkage popped of where it meets the link arm that goes into the tranny, bailing wire works wonders lol
Old May 19, 2017 | 08:08 PM
LiveIt!'s Avatar
Re: 84 Berlinetta
At least it got you home xD
