Overhead dome light 87 IROC Camaro
On Probation
Car: 1987 IROC-Z Camaro
Transmission: T-5 5 Speed
Hey guys...my dome light went out...all the fuses are good I believe...need to replace the light bulb I believe. How do you take out that white cover? Do you just kinda pop it out in the back? Dont want to tear it up, thanks guys!
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Overhead dome light 87 IROC Camaro
If you have the normal light with the square white lens you just put your thumb on one side. couple fingers on the other, squeeze gently and pull down.
Change bulb and snap it back in. Piece of cake!
On Probation
Yupp I took of the cover...super easy. The GOOD light bulb feel out. Seemed like the back metal connection clip was kinda pulled out to far...so I just gently bent it back some and it seems to be holding the light a bit better...hopefully it stays in there and dosent wiggle out...seems to be okay.
