Accessory fuse keep blowing.
Old May 21, 2017 | 02:02 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Transmission: 700-R4
My accessory fuse keeps blowing. Not sure why. What do I need to check for?
Old May 21, 2017 | 02:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Re: Accessory fuse keep blowing.
Often caused by a shorted out lighter socket(not the insert). To check just disconnect the plug on the back of the socket and replace the fuse and see if it holds. If that works either replace with a good one or leave unplugged, Be careful with the plug, the orange wire is always hot and you don't want it grounding out on anything.
Good luck
Henry
Old May 21, 2017 | 03:51 PM
IROCU2's Avatar
Car: 1987 IROC-Z
Engine: 5.7 TPI
Thanks hernryd3. I will try that.
Old May 21, 2017 | 05:48 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hope that works for you. And if you can't find the right replacement I've got some tested good sockets and lighters as well for pretty cheap
