Tach signal
Old May 23, 2017 | 12:48 PM
zgunz57's Avatar
Tach signal
I have a 89 iroc with a 94lt1 out of a vette swapped in. I installed the dakota digital VHX system everything is working except it will not pick up a tach signal to set up. I used the white tach wire from under the dash. Has anybody had this issue?
Old Jun 1, 2017 | 05:43 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Swap & Chop
Make sure there is still a tach signal on that White wire after the swap, by temporally hooking up a known good tach to it.
Happy Racing !
The Steering Wheel Turned Real E•Z When The Car Was On Its Roof
