Cant get Analog guages to work
Old Jun 18, 2017 | 01:40 PM
gmartin725's Avatar
Swapped an Auto in my 87 iroc with a 5 Speed W|C from a 91 TA I believe all 3rd gen my then used digital gauges Any suggestions to get speed or tach to work
Old Jun 26, 2017 | 04:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Dash 4 Cash
Your tach input wire needs to go to the PRIMARY of the coil.
The tach wire goes from the PRIMARY non-key side of the coil, to the firewall connector, to the dash connector, to the tach.
It’s a
White wire wire.
If the original is still there it’s a WHITE wire.
Speedo:
Find out if the 5speed is putting out a speed signal.
You can use an audio amp for that.
From there it connects to the Buffer Box located behind the instrument panel at the right.
You can use a GPS to find out if the speedo is accurate.
Happy Racing !
Here’s How To Judge The IQ Of Drivers On The Street: The Longer The Time From The Green Light To The Time They Start Moving, The Lower Their IQ
Old Jun 26, 2017 | 07:54 PM
NoEmissions84TA's Avatar
Re: Cant get Analog guages to work
But what can we do about it? Why is it that EVERY moron driver has to be right in front of me?
