Burning wires
Old Jun 20, 2017 | 05:02 PM
Ajpontiac's Avatar
Car: 64 goat
Burning wires
so i started a 84 ta that was in the garage for 6 years untouched . drove it around the block did this a few times over a few weeks. then smelt burning.. shut it off now nothing since well the red light on the dash comes on. a lot of wires to check car is all original every piece of plastic / gaurds are on .. idea where to start? fyi starter is good. is the coil inside the distributor cap on this year?
Old Jun 20, 2017 | 05:26 PM
Drew's Avatar
Re: Burning wires
I'd check the fusible links at the positive post of the starter, probably look at the fuses and ignition switch on the column... Alternator and battery cables would be good places to look for obvious burn damage too. You know, all the places power hangs around the water cooler.
Old Jun 22, 2017 | 01:37 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: Burning wires
As mentioned. Always start with the fuse box with any electrical problems.
Pull and look at each fuse. Do not forget what slot it came from.
Also, If the wrong fuse has been installed, as in "way" to "high" the wires can fry before the fuse blows.
Get a "book" or search on line for a fuse box diagram showing the correct gauge of fuse to be used for each component.
Old Jun 22, 2017 | 08:54 AM
Ajpontiac's Avatar
Car: 64 goat
Re: Burning wires
still no success in finding problem, order a repair manual. so i can follow each component..
Old Jun 22, 2017 | 09:19 PM
Engine: TBI,5.0
Re: Burning wires
Good idea on the Manual.
There fun to read. At least for me they are.
I have a 10 year old Chilton's and it shows it.
There is grease on every page.
randybdis
Oct 22, 2019 12:34 PM
RevenateRS454
Sep 21, 2016 08:16 AM
RunawayRadio
Sep 18, 2016 10:28 PM
johng1
Sep 18, 2016 06:07 PM
randybdis
Sep 14, 2016 01:57 AM
