What is this little rubber piece called?
Car: 1991 Trans Am GTA
Engine: L98(5.7 L TPI)
Transmission: 700r4(A4)
Axle/Gears: G80 RPO, 3:23s, Auburn Racer's Diff
Please reference the attached image.
See the orange piece on this connector? I lost one of these working under the hood of my car. (The piece I lost was to a one-wire connector, NOT a two-wire connector connector, as in the picture). What is this piece called? I need to order a replacement for the piece I lost.
It appears to serve the same function as an O-ring. I guess it's to keep moisture out of the electrical connection.
Thanks for your help!
Bill
Bill
Axle/Gears: 10 Bolt 2.73 Open
Re: What is this little rubber piece called?
The type of connector is referred to as a weather pack. That should get you started on a some productive google / duck duck go searches, or look on Amazon, eBay, etc.
I'm sure some users here have some favorite sources for those parts. Fortunately, I have not had the need yet.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Checkout this web site,they may have what your looking for.
http://www.clipsandfasteners.com/O_E...ells_s/259.htm
http://www.clipsandfasteners.com/Cav...l_p/a15950.htm
Transmission: 5-Speed Manual
