I need Fuse box help
Old Aug 1, 2017 | 01:02 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
all I need to do is pull out the pins in the fuse box. I need to put in new pins as some are burnt and broke. I have the new box. How do I get the pins out? I tired paper clips and screw drivers. I really do need help. Thanks
Old Aug 1, 2017 | 08:26 PM
HellHound's Avatar
Re: I need Fuse box help
Well I figured it out. They ARE clipped in from both sides. So I needed to pull the wires and push in on one side then the other. In case anyone is looking for this, because I found nothing out there.
It might be hard to see it. But on wiper, radio, and the one to the left you can see where part of the plug is missing. Causing the fuse to run amuck. This is the first time I have ever seen a thing like this.
Total of 21 pins needed
I had been trying for days and didn't want to break the pins.
Old Aug 3, 2017 | 04:06 AM
Cheerio's Avatar
Engine: 3.1 V6
Axle/Gears: No idea
cool you figured it out. for future use get some of these tools. make everything so much easier when rewiring:
Amazon Amazon
Old Aug 6, 2017 | 01:44 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Im a cheapskate.
http://www.ebay.com/itm/11x-Car-Term...72.m2749.l2649
