whats this switch?
Old Aug 7, 2017 | 11:03 PM
Evilokc's Avatar
Car: 1991 base firebird
Engine: tbi 305
whats this switch?
its the fan speed control switch on the a/c , heat controls on the left. mine works on all but high. if its on high it might as well be off because it doesn't allow the a/c or heat to blow at all. I want to replace it but none of my searches find the actual switch or part number.
Old Aug 8, 2017 | 12:12 AM
NoEmissions84TA's Avatar
Re: whats this switch?
https://www.thirdgen.org/forums/elec...-resistor.html
https://www.thirdgen.org/forums/elec...t-working.html
Old Aug 8, 2017 | 06:42 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
The head unit in the dash is probably fine. The issue is probably in the engine bay. The first three speeds go through the head unit but the high-speed is powered by a different circuit under hood. The head unit just triggers the high-speed relay.
Old Aug 8, 2017 | 07:10 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Qwk is correct, a couple things to look for on the high speed circuit.
I've seen the power wire connector (under hood) get hot and melt due to a bad connection (between HAVC box and pass side of motor) and I've seen the blower relays fail.
Old Aug 8, 2017 | 08:49 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Check this connector out. Usually melted all to He$$
Old Aug 10, 2017 | 06:58 PM
Evilokc's Avatar
Engine: tbi 305
thanks for the replies guys. I will have a look under the hood and see whats melted. hope its something I can find easily. if I understand this correctly fixing the high speed will NOT change the way the other 3 speeds work? its not going to make each speed stronger?
