passenger window won't roll completly up
Old Aug 16, 2017 | 09:51 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
My passenger window won't roll up all the way. It goes down fine and goes up fine until it stops at 3/4 of the way up. So I think the window motor is ok but I don't know. So can anyone help I don't want rain in my car haha.
Old Aug 17, 2017 | 06:57 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: passenger window won't roll completly up
The only possible help anyone here will be able to give you will be to tell you to take the inside door panel off and see what's keeping it from going up all the way . Something's either broken , or binding , or , , , tell me , no one has cut speakers into the doors have they ? Specifically in the areas where the door map pockets would be (if so equipped) ? If so , I have seen instances where people have cut speakers into the doors of cars and the window hitting the speaker and not going fully up or down was the usual symptom of a speaker install gone wrong due to the huge magnet most aftermarket speakers have sticking too far into the door .
I wish you luck ....
Old Aug 17, 2017 | 08:32 PM
Johny2234's Avatar
Car: 1990 Trans Am
Engine: 383 stroker
no their is no speakers because I have seen it with the door panel off. Looks like I need to take a look at what the problem is. Do you think I have a real pain in the a** on my hands.
Old Aug 18, 2017 | 07:45 AM
Abubaca's Avatar
Is it just stopping or does it appear to be binding? Mine was binding up. I would slowly come to a 90% stop, and creep the rest of the way. I could hear the motor struggling, so obviously I didn't keep doing this. ...for ME....turned out that I needed to adjust the triangle window trim piece. Once inside the door panel, I just kept playing with adjustments until it was smooth, and it sealed properly. Only took 3 or 4 tries to get it right. Maybe 20 minutes. There ARE other adjustments too, but I could see it binding on that piece, so that's where I focused my attention. You may have other issues, HOWEVER.....I think it's that triangle. About 3/4 of the way up is where the bottom front "corner" of the glass contacts that part of the guide. If out of alignment, it'll bind there. So my guess is adjust that triangle.
Old Aug 18, 2017 | 07:52 AM
Abubaca's Avatar
These are the 3 screws to adjust. Just loosen 'em and you'll see how the effect the adjustment. It's obvious once you start playin' with it.
Old Aug 18, 2017 | 08:39 AM
dlinger's Avatar
Car: 1984 Z28 HO
My 4th gen window motor would roll down fine but only go up 3/4. Sometimes I could turn off key and back on then it would move up some more. Replaced motor and works fine.
