Ls swap wiring help
Old Sep 2, 2017 | 04:18 PM
Blu_roc's Avatar
Ls swap wiring help
Hello all
I am finishing up my 90 iroc lsx/t56 swap and this may be a dumb question, but what am I supposed to wire the battery to? I'm assuming ground to body and motor on the negative side and I know it needs to hook to the alternator and starter on positive side but is that it? it needs switched ignition but where can I splice in to that? I also need to connect my harness to switched ignition but do not know where to do so. My tpi harness is gone and I have a bp automotive stand alone harness. Lastly my harness has a wire labeled fuel pump, should that be on switched ignition too?
Thanks in advance
