no spark need some help here
Car: 1987 Firebird Formula
Engine: 355
Transmission: Borg Warner 5 spd
Axle/Gears: 3:43
had the engine out of my 88 350 tpi and have no spark condition i have good ground on the yellow wire and no power period on the pink wire am I missing something here? all fuses inside are OK injectors prime and engine will turn over am I just missing a ground for the case of the coil to the chassis? not sure here?
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: no spark need some help here
No spark from the coil or no spark to plugs? If coil check ICM and pickup coil in dist, might not be sending a pulse to the ignition coil.
No power on the pink wire = no chance of spark
Time to track back and find out why. Might be something as simple as the ignition switch, might be a wiring problem including something wrong with the bulkhead connector.
Engine: 355
Axle/Gears: 3:43
where does the pink wire pull power from cant find a good diagram to see so i can run an overlay for it and see if it fixes it.
Engine: 355
Axle/Gears: 3:43
figured it out had the intake temp probe and the coil flip flopped like an idiot oh well easy fix
