Retard Due to Knock and Rollover Counter for Retard Due to Knock values
Hi,
I have a Firebird with the 3.1 engine from 1990. For diagnostics I use Efilive V4 which shows me that the values of Retard Due to Knock and Rollover Counter for Retard Due to Knock don't change.
Is this because I use the 1990Z24.xml mask to diagnostic my car?
Is it normal that both values do not change?
Thanks.
Thanks.
Car: check
Engine: check
Transmission: check
Re: Retard Due to Knock and Rollover Counter for Retard Due to Knock values
It is good that they don't change. If they did change, then knock is being reported.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Knock sensor is bad or lost the connectivity between it and the ECM (connector/wire).
RBob.
RBob.
Car: Fourth Gen '94 camaro
Engine: 350 Gen II
Transmission: A4
Please delete, worng forum.
Last edited by cardo0; Jun 2, 2019 at 03:17 PM. Reason: wrong forum due to related thread was included berfore posting
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Puma your posts are pretty detailed but I skimmed over a lot of the content because I recently had a similar maybe the same problem with battery bolts. I got a new battery at Sam's club and let the tech there install it. But it took the guy better part of an hour to install it. Result a few days later I was stuck - well it wouldn't start outside my garage with brand new batt. Had a batt tester and found battery voltage OK buy charge/capacity just so-so. Gave one of the cables a tug and man it was a loose goose. Tried to tighten myself and bolt just kept going roundy roundy. Closer inspection found the bolt was not long enough for the new EverReady batt. Had to use makeshift bolt and washers combo to get a tight terminal. But ya know I found all the part stores sell longer batt bolts for some reason. Almost $10 for 2 bolts but that was the fix. Sam's tire and battery tech should have mentioned it and kind'a dissapointed with them.
Hope this can help.
Hope this can help.
