Fog light lamp replacement Firebird from 1990
Old Sep 13, 2017 | 12:39 PM
Pupkin's Avatar
Hi,
does anyone know how to replace the bulbs of the fog lamps which are installed in my Firebrid from 1990?
Is there a description?
Thanks.
Old Sep 13, 2017 | 10:31 PM
Drew's Avatar
Re: Fog light lamp replacement Firebird from 1990
Remove the two torx screws at each side of the foglight lens, pull the lens assembly out of it's bucket, turn it over and unclip the paperclip looking wire, lift out the old bulb. Install the new bulb without touching the glass, replace the clip, blah blah...
Just FWIW stick with the standard 35W bulb, the housings cant dissipate the heat of higher output bulbs. 100W bulbs are brighter, but they'll burn out constantly.
Old Sep 14, 2017 | 07:20 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
a generic fog light kit sold at most parts stores and walmart, Blazer is one brand, is a direct replacement for the lamps, reflectors and lenses of the stock firebird foglights. at less the $20, you get to replace all of the above.
Old Sep 14, 2017 | 07:36 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Piece of mind....while changing the bulb, wear rubber gloves to prevent oil from your fingers getting on the bulb.
Old Sep 14, 2017 | 07:56 AM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
If you want pictures, start with post #299 on this page.
https://www.thirdgen.org/forums/memb...-1988-t-6.html
Old Sep 14, 2017 | 12:09 PM
Pupkin's Avatar
Thanks friends!
Very good information:
https://www.thirdgen.org/forums/memb...ml#post6066735
