Which turn signal lever to buy?
Old Sep 16, 2017 | 11:00 PM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Axle/Gears: 3.42 T2R
I'm trying to figure out what steering column signal lever I need to buy.
I have a 1992 RS, manual trans, w/ airbag, no cruise, 3rd gen wipers.
I will be keeping the 3rd gen column with tilt. The lever is pretty loose, lettering is faded, and it's non-cruise.
I'm currently doing an LS1 engine swap. I also have and plan to use a LS1 steering wheel with airbag & radio controls as well as the LS1 cruise control module. I have the rest of the entire steering column too. I have no issue tearing down both columns to mix and match.
Researching on here says I need to keep the 3rd gen multifunction switch to keep the wipers working correctly, tho I may need a new one seeing as the lever is loose. I believe I can just fish the wiring for the radio controls and airbag down the 3rd gen column. Then fish the cruise plug down from the stalk.
What lever do I need to buy? One for an '02 or one for a '92 or are they the same?
Old Sep 17, 2017 | 08:29 AM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Which turn signal lever to buy?
http://www.moderndaymuscle.com/inc/sdetail/160/531
Try Modern Day Muscle, they have a few to choose from.With or without cruise,with or without delay.
Old Sep 18, 2017 | 11:05 AM
GMan 3MT's Avatar
Car: 1986 Z28
Transmission: T5 WC
Yeah, found a few places with listings. Some have listings for 90-92, 90-93, 90-02. It makes me wonder if they are or are not interchangeable.
I'm guessing the wire/plug from the lever is for the cruise and is the same for '92 and '02. Those wires plug into the multifunction switch, correct?
