91 Camaro Intellitronix Gauges
Old Oct 4, 2017 | 03:50 PM
G92-Z28's Avatar
Car: 91 Z28
Transmission: 5 Speed
Axle/Gears: G92 (3.42)
Hi everyone,
After having my original gauge cluster burn and having trouble receiving my gauge cluster I ordered I really liked this digital cluster. Now I looked around on the forums and found some posts that were helpful but I think info is still lacking for the 91-92 clusters. I will try to add some helpful insight on my install but I was wondering if anyone could shed some light if they’ve attempted this themselves? Thanks for the help!
Old Oct 4, 2017 | 04:00 PM
G92-Z28's Avatar
Car: 91 Z28
Re: 91 Camaro Intellitronix Gauges
I did find this which can be helpful!
Old Oct 4, 2017 | 04:01 PM
G92-Z28's Avatar
Car: 91 Z28
I was trying to figure out how to wire the speedometer since there isn’t a cable in these cars so do you use the speed converter they send with the gauges?
Old Oct 4, 2017 | 04:05 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
On the original cluster #1 is the vss signal from the ecm. If your instructions are vague give the company a call for tech support.
http://docs.wixstatic.com/ugd/6a4159...c4c1a34aa4.pdf
