B&M relay part number
Car: 1987 Camaro
Engine: 5.7 TPI
Looking for the part number for relay on B&M megashifter.
Any recommendations would be much appreciated.
The one that was on my camaro was OEG SRE-202D the small wire in it melted which made my car not start. I tried to attach another thicker wire and worked but then stopped working not engaging starter until after a few clicks of turning the key which overhead relay and popping the crk fuse.
I have been looking for suggestions on what to use as a relay which says radio shack 275-206 but looks like others have had these overheat. Also read that B&M is including relay but can’t find that part number.
Thank you!
Thank you!
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Relaying Info
The relay you cite is for 3 to 10 amps depending on who you’re talking to.
Radio Shack 2750001 is for 40 amps.
To use it you will have to make a connector for it or wire it directly.
Happy Racing !
My Brakes Don’t Work AT ALL When The Car Is In The Air
Happy Racing !
