Underdash Wiring Help!!!
Old Nov 7, 2017 | 09:27 AM
87BlazinIroc's Avatar
Car: 1987 Iroc Z
Engine: 5.0L TPI
I was recently installing new kick panels in my 87 camaro irocz , and noticed when I removed the old panels there was two wires hanging , I removed the underdash cover on the passenger side and the wires run under the dash to a white block style connector , which has 3 wires , gray, white, and dk green , the on the other side of the connector has two wires which are pink and orange , not sure whether to splice these back together without know where they go , , also the white wire is hot at all times , green wire no power at all , thanks in advance
Old Nov 7, 2017 | 09:44 AM
Car: 1987 Iroc Z
Engine: 5.0L TPI
Re: Underdash Wiring Help!!!
Update- Traced the wires to the fender , and now I see that it's the antenna wires for the power antenna
