Stripped all wiring and needs to be road legal
Car: 1986 Camaro
Axle/Gears: Youkon
So I removed all the TPI harness from my 86 iroc so I could convert from a TPI to a carb set up. Had the car running and driving with all lights working for a while until I blew the trans and that’s when I ripped it all out to “start over” without thinking about my turn signals, brake lights and head lights. Long story short I really need to know how hard it will be to wire right into the column for the directional or should I run a 3 way toggle and cut my losses there? Also how hard is it going to be to wire up the brake lights? Reverse lights are all set since I put in a TCI fast gate shifter that came with the reverse switch.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Stripped all wiring and needs to be road legal
Why don’t you put back the c100 section of the harness.
Js92RS
Southern California Area
Dec 29, 2008 03:37 PM
