92rs Gauge Cluster swap INTO an 83z28
hey you guys, I just recently picked up a 92rs Camaro as a parts car for my 83z28 for only $50 bucks. I was wondering if there is a way to swap over the gauge cluster. the cluster from the 92rs is in perfect condition. plus I'm already in the process of swapping the steering column. so a third of the work has already been done. please help!!!!!!!!!!!!!!! all information is good information
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 92rs Gauge Cluster swap INTO an 83z28
Put the original steering column back in the 83Z if you want the wipers to work.
And forget about swapping the cluster too,..... they are simply not compatible parts.
Car: 1992 Z28
Engine: 383
Unless your ready to swap the entire electrical system over from the 92 into the 83 and the complete dash assembly. Its not an easy or quick job.
89RsPower!
Jan 14, 2003 03:58 PM
