Gas gauge dies with instrument panel lights
Old Jan 9, 2002 | 10:43 AM
Cityboy's Avatar
Strange problem but one I can live with: The gas gauge on my 87 camaro works fine intil I turn on the parking lights/headlight switch and illuminate the instrument display panel, causing the gas gauge needle to fall to the left empty indicator. If I dim the display panel with my parking light swith (turn to left), the gauge functions again (not much good for night time driving). I checked the fuse for instrument panel, and it is strong enough. Any advice?
Old Jan 9, 2002 | 04:52 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Sounds like one of the wires for the fuel gauge is touching one of the panel light wires. The back of the dash has the wires laminated in plastic, check for shorts and the condition of the lamination.
Old Jan 10, 2002 | 10:30 PM
Cityboy's Avatar
Thanks for the info. I assume this means pulling out the dashboard, or can they be reached from underneath?
Old Jan 10, 2002 | 10:35 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
no your going to have to pull the dash
Old Jan 25, 2002 | 10:58 PM
Cityboy's Avatar
May be ground
Electrical mechanic says the problem may be a ground down by the fuse box. He stated that there is a 10mm screw which the ground connects to, and I don't need to remove the dash to reach it. I will get to it this week.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
fonzie85
Aug 13, 2015 11:50 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
