wirning headlight motor relay
Car: Firebird
Engine: 3.1
Transmission: 700r4 /borg warner t5
hello is there a way to wire the headlight motor relay that the motor will pop up the headlights but the light is off ? i want to wire a switch for that
tanks
tanks
Re: wirning headlight motor relay
No need to rewire anything. Push the headlight switch On. Headlights pop up, and come on. With your fingertip pull the headlight part of the switch back. Parking lights should stay on, headlights stay up, but the headlight bulbs turn off.
Car: 1986 Trans Am
Engine: 305currently building a 350
Axle/Gears: borg warner antislip
1986 Trans Am HELP Feb 1,2026
what are the relay numbers ?
Is the isolation relay different then the left and right relay?
What wires go to which pinout?
