T56 & speedo
Old Jan 12, 2002 | 09:17 AM
checkeye's Avatar
T56 & speedo
I have an 86 mechanical speedo, LG4 computer carb.
Swapped in a 95 T56.
If I get an electronic speedo from a later model, '90 up?, will the VSS from the trans interface with the speedo or does the computer do this?
In other words do I also need the computer from the electronic speedo donor car?
Or
Does the electronic speedo just read from the VSS?
thanks...
For future reference:
Yes the Dakota Digital unit reads directly from the VSS on the trans, ECM is not needed...
Old Jan 14, 2002 | 05:46 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The electronic VSS would have to be connected to a VSS buffer (small module used on digital dash Berlinettas, digital dash T/As and 5.0 TBI F-bodies) and then fed to the ECM VSS input. The mechanical speedo can't be (easily) driven from the electronics, as far as I know. You may want to get an aftermarket electronic speedo, or a GM electronic speedo movement & install it in your stock cluster & drive it from the VSS buffer module, as well. Cyberdyne may have some insight into the conversion, as well.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Vincent135
Sep 28, 2015 10:50 PM
