ecm reprograming/ wiring harness
Old Jan 13, 2021 | 07:23 PM
windsock's Avatar
Car: 86 Trans Am
Engine: Lt1
Transmission: t-56
I've got a 93 lt1 in a 85 TA not firing because of the anit theft. Anyone doing a reprogram of ecms or doing a stand alone wiring harness to eliminate the TDM??
Old Jan 13, 2021 | 07:39 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: ecm reprograming/ wiring harness
16159278 ecm ? You can get a hz module off eBay or pm me I can disable vats.
Old Jan 30, 2021 | 08:32 PM
Grubby146's Avatar
Car: 91 camaro RS
Engine: 305 tbi
Axle/Gears: 2:73
I've got a ecm that's needs vats takin out for me. Can you help me out and if so at what cost
Old Jan 30, 2021 | 08:46 PM
Engine: Lb9
Transmission: M20
Send me a pm with what you have and I’ll see if I can help.
Old Apr 20, 2021 | 10:48 PM
Cris92RS's Avatar
Car: 92’ Camaro
Hey Windsock. I have a question regarding your swap to be specific the wiring harness. Where did you hook up the oil pressure wire coming from the C100 did you hook it up directly to the sensor or to the lt1 harness and same goes for the coolant wire.
Old Apr 21, 2021 | 01:33 PM
windsock's Avatar
Car: 86 Trans Am
Engine: Lt1
Transmission: t-56
I know the coolant I used the 85 wire and changed it to electric fans used there sensor you may have to change the ends on the oil and coolant you should be able to use the wires in the old harness.
QUOTE=Cris92RS;6423347]Hey Windsock. I have a question regarding your swap to be specific the wiring harness. Where did you hook up the oil pressure wire coming from the C100 did you hook it up directly to the sensor or to the lt1 harness and same goes for the coolant wire.[/QUOTE]
camaronut396
Jun 17, 2017 10:31 PM
bondodude86
Jun 14, 2011 05:15 PM
vwaltdog
Nov 12, 2004 03:29 PM
