Low beams fail
Low beams fail
Hello I'm new member in this forum, i'm from Spain, sorry for my bad english, I try to learn.
I have a problem in the low beams. Recently my alternator broke, it produced 16v, from that moment on when I turn on the low beams only one works for me, when I turn on the high beams all four work which means that it is not the bulb. I have checked the fuse box and everything is ok. It does not occur to me that it can fail, can someone advise me? Thank you
Re: Low beams fail
Hi Blue84Spain, welcome to TGO !As to your question, the outermost two headlights on your Camaro have two filaments in them, a low beam and a high beam filament. Meaning that yes, you do most likely have a low beam filament burnt out in the headlight that won't light on low beam. Replace that bulb and I'll bet your problem goes away(make sure to buy the correct bulb type H4656)
Re: Low beams fail
bubbakutz
Jan 5, 2003 10:05 PM
