1988 Firebird digital cluster
Old Mar 5, 2021 | 09:47 PM
Freakester1974's Avatar
Just swapped out a 305 TPI to a 383 Stroker carbureted.The digital gauge cluster will light up but wont display. No fuel, volts, temp, oil pressure and no odometer .I'm thinking a common ground but not sure. Any ideas? I'm not an electronics guy.
Old Mar 23, 2021 | 01:50 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Re: 1988 Firebird digital cluster
I believe there is a ground that needs to be hooked up in the c207 connector that was probably removed when the tpi wiring was removed. I can look more into this after work.
John in RI
Apr 1, 2014 11:49 AM
Dingley
May 23, 2004 06:13 PM
89-28gp
Sep 10, 2001 02:13 AM
