Wire harness
Old Oct 7, 2021 | 05:54 PM
Jordan Ruddick's Avatar
Wire harness
Hello I'm swapping a 350 into my camaro and I have a v8 harness from a 92 and I have my interior harness from my 85 which was a v6 will they work together? Or do I need a new interior harness I ask because where they meet on the passenger side the interior harness has a extra plug that the v6 had plugged in
Old Oct 7, 2021 | 06:49 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: Wire harness
You haven't given enough details about what you're planning for induction on the V8 for anyone to give informed advice. The pinout for the 92 and 85 are different on both the C100 and C207 connectors. Some wires are the same, but it changes depending on the year and engine
Old Oct 7, 2021 | 07:35 PM
Re: Wire harness
well I'm doing a 350 tpi from a 91 92 camaro and the harness is from that but I was hoping to use my interior harness from my 85 but like I said the tpi harness is missing a connector by the passenger side firewall so I was wondering if it'll even work
Old Oct 7, 2021 | 07:47 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Re: Wire harness
Post a picture of the connector it's missing, and/or the cut wires and where they are located
Old Oct 7, 2021 | 07:57 PM
Re: Wire harness
The v6 had 3 connecters from the computer and the v8 only has the 2
Old Oct 7, 2021 | 09:22 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Wire harness
I found it easier to convert the entire interior from my 87 to a 92 set-up than to try and deal with making the 92 harness work with the 87 harnesses. ( 87 2.8 was swapped to a 92 3.1 )
The 3rd plug on the 85 Dash harness is called C221; the heavy PINK/Black wires are for the Injectors, Brown is for the Fuel Pump-Fan Fuse / Fan Relay. You'll find just about all the the wiring info you would need to hack/splice the 92 and 85 harnesses together on these to pages: ( I'd recommend getting a 85 and a 92 service manual so you have EVERY schematic you could possibly need. )
https://berlinetta.info/C100.htm
https://berlinetta.info/C207.htm
Jordan Ruddick
Oct 7, 2021 05:53 PM
punkmaster98
Interior Parts Wanted
Sep 18, 2018 05:44 PM
WASyL
May 26, 2009 01:58 AM
frankq26
Jul 10, 2008 10:07 AM
