89 Trans Am gauge LED help
Old Nov 25, 2021 | 12:19 PM
adixon816's Avatar
Hi everyone I pulled the gauge cluster out of my 89 Trans Am however all the guides I found for LEDS were for Camaros and the clusters are different. I bought the tool to check polarity on the LEDs themselves but how do I know on the board the correct orientation for the positive and negative positions? It looks like trace 3 from the to touches every single bulb so I'm not sure if that's a common ground. Any help is appreciated.
Old Nov 26, 2021 | 01:18 PM
adixon816's Avatar
Re: 89 Trans Am gauge LED help
In case anyone runs into the same issue I wanted to post the solution
Old Nov 26, 2021 | 04:10 PM
OrangeBird's Avatar
Car: 1989 Firebird
Thank You for posting your findings on this, it'll surely help someone in the future whose doing LEDs in their dash.
So now, the all important questions ; How do they look? Brightness and color OK? And if you do like them, what brand/type did you use?
Old Nov 26, 2021 | 07:09 PM
adixon816's Avatar
Sorry didn't even think to post pictures brightness and color were good I used Partsam 6 -3528 LED chip bulbs with their turn lock plugs. The original bulbs were clear with an orange cover for that orange/red factory color I wanted white. I put white bulbs in everything except high beam and turn signals indicators which I used blue and green but white would have worked as the indicators are colored on my gauges. These LEDs also dimmed with the factory dimmer. I am very pleased how they came out.
PTS
Fabrication
28
Sep 28, 2022 08:44 AM
themanoncan
Aug 14, 2007 09:43 PM
Thirdgen89GTA
Jan 16, 2005 08:55 PM
myfast3rdgen
Nov 9, 2004 11:07 PM
