C100 questions for an 87 roller
Old Sep 13, 2022 | 02:18 AM
DigitalCannon's Avatar
Hey everybody,
I've got an 87 Firebird I'm trying to wire, but because most of the wiring was removed by the previous owner I'm having a hard time figuring out some parts of the C100 harness.
Specifically, I'm confused about pins F8, G5, G7, and A1. My source for my existing information came from https://berlinetta.info/media/shopma...Firebird87.jpg
Questions:
  • Pin F8
    • Labeled as "Charging System". Is this something for the alternator?
  • Pin G5
    • Labeled Power Distribution for the fuse block
    • Does this get connected to battery?
  • Pin G7
    • The label provides 3 options. Is radiator power correct?
  • Pin A1
    • Labeled Power Distribution for headlight doors
    • Does this provide power to the headlight doors, in addition to pins D1 and D2?
    • Or, should this also be connected to the battery.
Any insight would be appreciated. Thanks!
Old Sep 13, 2022 | 09:18 AM
Re: C100 questions for an 87 roller
F5: yes. Goes to the "field" terminal on the alt. The alt has 2 terminals; one is "sense" (that's the one that the regulator adjusts the alt's output according to, to keep the voltage at that specific point in the system at a constant voltage). "Field" is closer to the output terminal, "sense" is the farther away one.
G5: yes. Big Red Wire. Comes from one of the fusible links and feeds various direct-battery consumers in the cabin.
G7: not sure about that one. Probably not "radiator power" in any case. Might possibly be the + side of the fan relay coil, with the - side being the fan switch in the pass side head or the ECM. That other wire to the fan relay coil will be green w/ white stripe.
F4: not sure why you have that marked "won't use". That's the Big Pink Wire that goes to the distributor; high-power switched ignition. Best place to pick up that feed to send to your aftermarket wiring.
D1, D2: probably the "signal" wires to the HL motor system, telling it that the HLs (either low- or high-beam) are on. One wire for low, the other for high.
A1: not sure about that one either. Can't recall how Firebirds are wired in that area although it seems more logical that it would be a fused "output" going to the relays to power the motors. Look for a fuse or circuit breaker inside the cabin.
Old Sep 13, 2022 | 10:08 AM
Big thanks! With everything else hooked up, figuring out what A1 is for won't be hard.
I'll post my updated spreadsheet in case it helps anybody:
ThraxXx
Sep 8, 2010 12:33 PM
Gadp74
Aug 28, 2009 06:09 PM
JekyllandHyde
Nov 19, 2008 06:28 PM
89FormulaRoth
Feb 5, 2008 08:04 PM
WhiteGhost
Mar 21, 2002 08:48 AM
