Headlight Module Question
Old Sep 22, 2022 | 10:17 PM
jacob83Z28's Avatar
So I bought a headlight module for my 88 Firebird off of a guy who had a Firebird. Little did I know that there are 2 different modules for different years. His car was a 91. My question is that if there’s any way I can wire this module to work on my 88? Maybe switching a couple wires around? Idk just looking for alternate solutions is all. TIA
Old Sep 22, 2022 | 11:59 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: Headlight Module Question
Nope.
But you can go to the junkyard and get one out of a C5 Corvette.
Post #1561, https://www.thirdgen.org/forums/ltx-...ml#post6402215
Old Sep 23, 2022 | 03:02 PM
OrangeBird's Avatar
Car: 1989 Firebird
If you were willing to swap some wires, yes you could make it work (provided it is a properly functioning module, of course).
Looking at the 1988 and 1991 headlight wiring diagrams, you'll notice the only two differences are that the 1988 has a white wire that needs to see +12v when the lights are off, whereas the 1991 uses a brown wire that needs to see +12v when the lights are switched on. Since your trying to use the later module in the earlier car you'd need to satisfy the brown wire circuit. The second difference of note is that if you look closely at the motor's wiring, the wires are opposite and you would need to repin the connectors such that the correct motor wire colors go to the correct module terminals as indicated on the 1991 diagram. Take care of those two items and you'll have a working 1991 module in your 1988 car......
Old Oct 4, 2022 | 01:03 PM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Retrofit Firebird Headlight Control Module (2-Wire Motors) (1984-1992 Firebird) - BraveTECH
Old Oct 4, 2022 | 09:13 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
i got a headlight mod from a c5 vette $100 off ebay works perfectly
LT1Formula
Exterior Parts Wanted
Sep 21, 2014 05:24 PM
bmxerboi221
Jul 11, 2009 09:29 PM
slygy0
Jan 7, 2007 05:54 PM
