Radio bulbs, all pullouts??
Old Nov 16, 2022 | 02:31 AM
TomBangkok's Avatar
Car: 1989 IROC Convertible
Engine: 350 Corvette LT1 -93
Transmission: TH350
Hi,
I need some advice on my stock radio bulbs. I managed to pull plout two of them, but are the remaining two soldered to boards? Or are the holders soldered and I just need to try harder to pull them out? Thanks in advance...
The small circles I could pull out.
Old Nov 16, 2022 | 06:06 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Radio bulbs, all pullouts??
IIRC, there is at least one that is soldered to the board. The bulb is mounted in a small holder, then soldered in.
RBob.
Old Nov 17, 2022 | 05:29 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
RBob nailed it !
The bulb all the way to the right,... that's the one that's soldered-in. Most (cheap) aftermarket bulbs will require you to reuse the original holder. The original bulb is a 14 Volt, 80ma bulb Part number 'OL330BP".
** Just found these; good price too.
https://www.interlightus.com/light-bulb/OSHINO-OL-330BP
** The other 2 push-in style bulbs are the same bulbs used in various other GM cars/trucks. I usually get mine from ( about ) 97-02 S10 sun-visors.
wim
Car Audio
Sep 3, 2015 03:17 PM
5.0ta
Car Audio
Jan 7, 2015 10:05 PM
tsev
Car Audio
Oct 3, 2012 09:58 AM
aaron7
Sep 1, 2003 05:41 PM
