85 Iroc 305 MFI suddenly acting bizarre… ecu?
Old Aug 22, 2023 | 12:43 PM
Aaronl84's Avatar
On a drive this morning, out of nowhere, the car starting bucking and sputtering, some of the gauges are no longer responding -
oil pressure going to full when cranking then zero while running,
tach is now inop, voltage inop, check engine light no longer comes on when cranking
engine starts, but now has a rough idle, and does not wanna take gas easily, it will rev, but coughs, and shifting is harder.
coil?
ecu?
Old Aug 22, 2023 | 02:39 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 85 Iroc 305 MFI suddenly acting bizarre… ecu?
Yep, has to be the ECU, always is. It is responsible for every malady in a cars life...
Just rip it out, bypass it and all will be good.
RBob.
Old Aug 23, 2023 | 08:39 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
coil?
ecu?
It could be just about anything causing the symptoms you describe, but I'd suspect an electrical issue first.
Start with the basics; check all the harness connectors and all ground connections.
Old Aug 23, 2023 | 12:53 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Could be distributor.
Old Aug 23, 2023 | 01:53 PM
Aaronl84's Avatar
Would thendist cause the gauges in addition to the tach to go dead and no CEL?
shane_429
Sep 28, 2010 09:38 PM
Rumpy1
Oct 2, 2009 10:16 PM
MR. KIDD
17
Oct 12, 2003 09:02 AM
