1991 Camaro with 1989 motor swap
Old Jan 6, 2024 | 08:41 PM
tysonmel's Avatar
Car: 1991 Camaro rs convertible
Any info helps especially if someone has done this before but I have a 1991 Camaro rs that had a 305 cid tbi motor in it and I’m putting a 305 tbi motor from a 1989 rs and everything seems to be the same mainly other then some of the plugs from the harness on my 1991 don’t match with the plugs on the 1989 motor so I’m just curious what I should do or if there might be any issues
Old Jan 7, 2024 | 04:03 PM
BBCSwap's Avatar
Engine: SBC Dart 400 Holley 750 Carb
Axle/Gears: 28 spline 323 gears
Re: 1991 Camaro with 1989 motor swap
Use everything off the 91 and you should be fine.
dewfamily
May 22, 2011 10:52 PM
mikal1809
Jan 30, 2009 12:33 PM
critter2655
Feb 20, 2008 09:21 PM
REX
Apr 19, 2005 07:53 PM
